Home > Message Board > Home Audio > Mini Systems > Need help !!!!!!!!!!!!!! is this poss...
Author Thread: Need help !!!!!!!!!!!!!! is this possible???????
Username: Fatkid
hey, i have a 12inch ESA subwoofer its 75 watts rms and 225 max. i was wondering if there is a way to hook it up to my minisystem?possibly with a car amp? it's a sharp xl-es50 it has a subwoofer port that regular speaker wire from the sub into. the sub that came with it is 40 watts rms and 80 max.i really would like to use this sub. Upload
Relevant Product Info
Username: Gamerdude
Kitchener, Ontario
well if you no what the ohms are for the sub taht came with ur system if its 4ohms then you can run the sub its not there no point you will mess up ur amp heres what you do get a case/box for the sub and the get some speaker wire hook one end to the sub and the other to the amp and ur rdy
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Mini Systems > Need help !!!!!!!!!!!!!! is this poss... [ « Previous ] [ Next » ]
