Thread: Nad c 320bee & B&W 602s3 how far can you go? |
New member Username: Casa7
Post Number: 2 Registered: Jan-06
| Posted on Friday, January 06, 2006 - 03:55 am: |
to all the nad c 320bee & B&W 602s3 owners out there. can the B&W 602s3 play really loud without distortion? i've experienced cranking up the volume (volume at 11 o'clock) with acoustic energy aegis evo 1 and the bass starts craking. does this happens with the B&W 602s3? |
Bronze Member Username: Davidpa
Portland,
Oregon
US
Post Number: 90 Registered: Nov-05
| Posted on Friday, January 06, 2006 - 10:28 am: |
volume at 11 oclock means nothing, except your probably clipping your amp at that point. Even if you get a better amp, although the volume will be louder at 8 oclock than your current setup is at 11 oclock, if you decide to go back to 11 oclock it will just clip again as you are exceeding amps output at that timeframe. looks to me like it would be bedtime anyway at that hour. |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 7099 Registered: May-04
| Posted on Friday, January 06, 2006 - 10:45 am: |
602's do not play "really loud". Speakers with a sensitivity specification about 10dB higher than the 602's play really loud. Buy speakers rated in the upper 90's for sensivity/efficiency and you can play really loud with the volume at 11 O'Clock.
Silver Member Username: Gavincumm
New York
Post Number: 468 Registered: Feb-05
| Posted on Friday, January 06, 2006 - 11:44 am: |
all you are going to do is blow a perfectly good set of speakers. Can I get my hands on them before you do? |
Silver Member Username: My_rantz
Australia
Post Number: 127 Registered: Nov-05
| Posted on Friday, January 06, 2006 - 12:17 pm: |
The 602S3 sensitivity is stated at 90dB spl (2.83V, 1m. On my C162/272 combo these beauties can fill our reasonably large living room with copious volume with the dial set at about 10.30, any higher would result in roof repairs. So, if they don't play "really loud" then imho, they play "loud enough." |
Post Number: 6 Registered: Jan-06
| Posted on Friday, January 06, 2006 - 12:37 pm: |
the thing that i still can't understant is why do manufactures make aplifiers that we can only use half of the volume control (12 o'clock)??? What happends to after that and why???? |
Australia
Post Number: 129 Registered: Nov-05
| Posted on Friday, January 06, 2006 - 12:53 pm: |
There are many variables relating to your question such as room size, speaker sensitivity, speaker power rating, speaker impedence and impedence swing etc. The amplifier never knows who is going to pair it up with what set of speakers. Where some speakers may require "12 o'clock" on the amp's dial to play at a certain volume, others may require "2 o'clock or "10 o'clock". What happens after that and why? Maybe that's a question for Stephen King :-)
Dallas,
TX
Post Number: 7101 Registered: May-04
| Posted on Friday, January 06, 2006 - 04:24 pm: |
As Rantz suggests the position of the volume control is relative to what is happening elsewhere in the system. Input vs. output, efficiency of the speakers, tone control settings and log vs linear taper on the control itself. Most amplifiers run out of clean wattage at not much more than 12 O'Clock on the volume control. Do not expect an amplifier to be able to have the volume control turned as high as it will go. If you want "really loud", you need to have very efficient speakers. 90db is good but 10dB more in the sensivity spec is like having ten times the wattage. You will probably also have drivers that are meant to take some punishment if you shop for efficient speakers. If your speakers are "cracking" at 11 O'Clock on the volume control, you would likely be playing some bass heavy music. Buy some speakers that are meant for that purpose and try not to destroy the Energy's until you can swap out speakers. |
New member Username: Mrbeefy
| Posted on Friday, January 06, 2006 - 06:09 pm: |
LOL... Is this a Cerwin Vega situation??? |
Dallas,
TX
Post Number: 7103 Registered: May-04
| Posted on Friday, January 06, 2006 - 07:19 pm: |
No.
Silver Member Username: Nuck
Parkhill,
Ontario
Post Number: 979 Registered: Dec-04
| Posted on Friday, January 06, 2006 - 07:54 pm: |
Dr. Klipch, Dr Klipch to the incoming thread! |
Post Number: 7 Registered: Jan-06
| Posted on Saturday, January 07, 2006 - 09:52 am: |
I've owned a pair o cerwin-vega vs-8 and, to be true, for heavy bass music they rock, but you loose a lot in detail. I m just looking for a speaker to play in a small room, that can handle both heavy bass music and detail for around 500USD. most of the opinions i've read, the B&W 602s3 are ideal I just have to go to my dealer and hear them. But if anyone can suggest any ohter speaker i would appreciate. |
Dallas,
TX
Post Number: 7109 Registered: May-04
| Posted on Saturday, January 07, 2006 - 11:06 am: |
http://search.yahoo.com/search?p=high+efficiency+loudspeaker&sp=1&fr2=sp-top&ei= UTF-8&SpellState=n-307170836_q-nMwMk.SRndPoj7xPDcSpQwABAA%40%40
Australia
Post Number: 130 Registered: Nov-05
| Posted on Saturday, January 07, 2006 - 12:58 pm: |
As Jan stated, higher efficiency speakers will play louder, but if your room is small the 602's, imho, will certainly deliver on your requirements. It's only up to your ears on what you finally decide. Me, I find them hard to beat for a decent speaker in their price range (and well above in many cases).
ererererer Unregistered guest |
| Posted on Saturday, January 07, 2006 - 03:21 pm: |
I have never seen speakers with 100 dB sensitivity in the hi fi brands Can anyone please suggest bookshelf speakers with such high sensitivity? Thanks Eduardo |
Dallas,
TX
Post Number: 7115 Registered: May-04
| Posted on Saturday, January 07, 2006 - 11:08 pm: |
Probably not. The three most basic parameters a speaker designer will juggle are bass extension, sensitivity and enclosure size. When you change one, you change the other two. High efficiency speakers are inherently larger boxes. The original Klipsch Heresey was spec'd at 96 dB @ 1 watt. Most high efficiency "bookshelf" systems will be slightly less than that spec. Anything higher is likely to be a floor standing speaker. |
| Posted on Sunday, January 08, 2006 - 02:30 am: |
Thanks, refrasing my question. What bookshelf speakers have the highest sensibility in the 300 to 600 usd range? Eduardo |
Silver Member Username: Ca_convert
Cardiff UK
Post Number: 172 Registered: Jan-05
| Posted on Wednesday, January 18, 2006 - 08:13 am: |
I have the 602 S3's driven by a NAD C352. Exactly how deaf do you want to get, or are you planning on using the system as an outdoor PA???? |
