Thread: Jumper bars question |
Bronze Member Username: Wigglyman
Post Number: 15 Registered: Dec-03
| Posted on Tuesday, January 03, 2006 - 04:46 pm: |
Perhaps some of you experts can answer this question: I always see the warnings in manuals stating "DO NOT attempt to bi-wire or bi-amplify unless you have removed the jumper bars." I'm just curious, not being an electrician, why this is a problem...would it adversely affect the sound only or would it actually damage the speaker? |
Silver Member Username: Nuck
Parkhill,
Ontario
Post Number: 945 Registered: Dec-04
| Posted on Tuesday, January 03, 2006 - 06:51 pm: |
bi-wiring will destroy nothing, if you maintain polarity, you are simply creating a parallel circuit. Bi -amping will blow up your power source, or just shut it down, if you are lucky. |
Post Number: 16 Registered: Dec-03
| Posted on Friday, January 06, 2006 - 05:14 pm: |
Thanks Nuck...so clearly bi-amping with them on is a problem, but why do they say to remove them for bi-wiring? Does it affect the sound? |
Parkhill,
Ontario
Post Number: 977 Registered: Dec-04
| Posted on Friday, January 06, 2006 - 06:53 pm: |
Marginally so, in my opinion. Alternativally, remove the strips and replace with speaker wire
