Home > Message Board > Home Audio > Speakers > Archive through January 12, 2006 > Question: How to connect TDL speaker...
Author Thread: Question: How to connect TDL speakers to amp?
I have TDL Studio 3 speakers, about 20 years old. Each speaker has 4 output posts, 2 marked "high" and 2 "low." But the amp only has 2 post inputs for each speaker, labeled + and -. Can someone please tell me the correct wiring configuration please? Thank you!!
Username: Davidpa
Portland, Oregon
US
Post Number: 82
use a jumper for the speaker terminal to combine high and low, or bi-wire from amp to speaker.
Username: Nuck
Parkhill, Ontario
Post Number: 913
jhk, make 2 jumpers for each speaker make from your speaker wire. each should be about 6" long.
connect each + and - post tobether.
Now introduce the power wires to the speakers, placing the + from your receiver to the + post of the bass(lower).
Wire the - to the - post or your upper(top) post.
Home > Message Board > Home Audio > Speakers > Archive through January 12, 2006 > Question: How to connect TDL speaker... [ « Previous ] [ Next » ]
