Home > Message Board > Home Audio > Subwoofers > Archive through April 04, 2006 > What subwoofer do you recommend?
Author Thread: What subwoofer do you recommend?
Username: Want2noaudio
I have the Kef Q-7 and the matching center channel the Kef Q-9c with the Q-1 as the rears. My question is what sub to you lean towards in the 500- 1000 dollar range? I was considering the Kef PSW 2500 , Aperion Audio Intimus S-10, Outlaw LFM-1 or the Jamo D-4. Your advice would be helpful...
Thanks
Username: Artk
Albany, Oregon
Post Number: 2552
That Outlaw is a stellar buy and one of the first I would look at for HT at that price.
Username: Jan_b_vigne
Dallas, TX
Post Number: 7060
http://www.us.alegriaaudio.com/Tom%20Subwoofer.htm
Dallas, TX
Post Number: 7061
http://home.comcast.net/~infinitelybaffled/page2IB-Gallery.html
http://www.t-linespeakers.org/projects/steve/
Username: Rysa4
Post Number: 277
Hey Jan- I dont think I can get that last one through the door!!
Thanks for the advice... The only thing with the the Outlaw is , it comes in any color as long as its black.. The wife wants dark apple or a medium cherry to go with rest of the equipment...
Thanks.
Username: Edster922
Abubala, Ababala
The Occupation
Post Number: 3517
The Hsu STF-3 is very similar to the Outlaw (designed by the same Dr. Hsu) and I think is available in other colors.
hsuresearch.com
Thank you Edster for the advice...
Username: Edster922
Abubala, Ababala
The Occupation
Post Number: 3520
You're very welcome. Let us know what you choose and how you end up liking it.
I belive we are leaning towards the HSU- VT-F3 MK2 in a Rosewood finish.. Once again thanks for the advice...
Username: Gavincumm
New York
Post Number: 458
try this...
http://www.norh.com/products/sub/index.html
read up on it before you decide what to do. n0rh has a cult following in the audiophile community, and it is well deserved. Their subs come in marble and teak. To say they are beautiful is an understatement. Take a look at the teak sub on the pricing page.
I have heard a pair of n0rh speakers, and found them very engaging, with a very inviting personality. If the subs are designed with the same passion, you won't be dissapointed.
There is also an informative section in there describing how cheap sub amps create harmonics to trick the brain into thinking bass is actually being created, and what the n0rh sub will and won't do.
It is a very informative website that will tell you how to find a great sub, even if you don't like what you find here, so PLEASE take a look.
lafowtlowd
BOSE, BABY!!
goggly nuhhuh
bose, baby!!
Username: Stevo
Margate, FL.
Post Number: 8
SVS PC 20-39+
Username: Dobyblue
St. Catharines, Ontario
Post Number: 27
Give either the PW2200 or the Seismic 12 a test from Paradigm.
Unless money's no object or size then look at the Servo 15 from Paradigm.
Username: Gman
Mt. Pleasant, SC
Post Number: 814
I would go for the HSU VTF-3 MKII, the SVS PB12 Plus in cherry or rosewood @ $999, or the Onix UFW-12 with R-DES (includes parametric program for balancing 100 mhz and down) @ $1099.
Username: Unreal_t
United States
Id look into Polk Audio Subwoofers. They are really a great company to trust!
Home > Message Board > Home Audio > Subwoofers > Archive through April 04, 2006 > What subwoofer do you recommend? [ « Previous ] [ Next » ]
