Home > Message Board > Home Audio > Integrated Amps > Archive through March 02, 2006 > Best IA with an alarm
Author Thread: Best IA with an alarm
I'm looking for a 2 channel IA between $200-600 that will work well with my Totem Mite speakers (see thread http://forum.ecoustics.com/bbs/messages/1/105572.html).
The only glitch is that I need the IA to also function as an alarm clock; meaning the amp displays the time even when it is off and turns the sound on at a set time (preferably I'd like the sound to increase grandually when the alarm activates just like the JVC stereo systems do).
mmalleson
I should add that I'd also be happy with a non-integrated amp.
Username: Nuck
Parkhill, Ontario
Post Number: 903
mmall, maybe you need your Mom to live there and kick your butt out of bed.
Just buy the JVC then.
mmalleson
I don't want to buy the JVC because the sound isn't high quality and the system comes with speakers which I don't need.
As for the question about my mom, I just moved out a few months ago and I'd rather buy a fully functional receiver than move back in with my parents.
Username: Frank_abela
Berkshire
UK
Post Number: 1126
You can try the NAD L53 which is an all-in-one stereo machine (DVD/Tuner/amp/clock-timer). Should work reasonably well with Mites, though I haven't tried it myself.
Regards,
Frank.
Home > Message Board > Home Audio > Integrated Amps > Archive through March 02, 2006 > Best IA with an alarm [ « Previous ] [ Next » ]
