Home > Message Board > Home Audio > Mini Systems > Why does no body answer me!!!!!!!!!!!...
Author Thread: Why does no body answer me!!!!!!!!!!!!!!!!!!!!!!!!!!!
Username: Fatkid
i have a sharp mini system xl-es50 and i was wondering if it is possible to hook it to my computer and how to do so if possible
Relevant Product Info
Username: Happyhillbilly
If it has an audio out port (headphones or line out) and your computer has a line in port, you could record any sound coming out of the system.
Username: Stereocollector
You can use the headphone jack of the computer. If you buy a cable with one end being the same as a headphone connector, and the other end having the red and white connectors (I think it's called an A/V cable), there should be an input at the back of the stereo.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Mini Systems > Why does no body answer me!!!!!!!!!!!... [ « Previous ] [ Next » ]
