Thread: Bookshelf speakers |
dave in Pa. Unregistered guest |
| Posted on Wednesday, December 21, 2005 - 01:49 pm: |
my wife has an onkyo receiver tx 906...and wants a pair of bookshelf speakers. they can be up to 7 1/2" wide. she presently has an old pair of floor model HK speakers from an old all in one system. one stereo shop i called has paradigm atom for $200 another has polk 30...same price can you recomend any others or are these ok... i'd prefer to stay in the less than $200 price range thanks...Dave |
Silver Member Username: Chitown
Post Number: 577 Registered: Apr-05
| Posted on Wednesday, December 21, 2005 - 02:25 pm: |
You can try the Aperion Intimus 422-LR. A set of A-stock will cost about $180 shipped.
Silver Member Username: Gavincumm
New York
Post Number: 445 Registered: Feb-05
| Posted on Thursday, December 22, 2005 - 07:50 pm: |
the paradigm atom will be a better bet than the aperion if you don't want to use a sub. They can be used alone for casual listening to my ears.
Gold Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 3447 Registered: Mar-05
| Posted on Thursday, December 22, 2005 - 08:18 pm: |
Wharfedale Diamond 8.2s from buy.com or Athena AS-B1s from audioadvisor.com |
Post Number: 587 Registered: Apr-05
| Posted on Friday, December 23, 2005 - 11:18 am: |
Wharfdales are bigger than the size he specified. Can't find much info on the Atom on the Paradigm website. I would also recommend the Monitor Audio R90. They work very well without a sub, but you would have to go to the $300 range for them.
New York
Post Number: 446 Registered: Feb-05
| Posted on Friday, December 23, 2005 - 12:32 pm: |
take it from someone that HAS the atoms (ie: myself) that they work very well for casual listening without a subwoofer. |
