Home > Message Board > Home Audio > Preamps > Any 4ohm to 8ohm converters??
Author Thread: Any 4ohm to 8ohm converters??
Username: Ironhorse
I have 2 car subwoofers that are 4ohms and I need a way to convert them to 8ohms for my home receiver.Any suggestions
Relevant Product Info
Username: Jan_b_vigne
Dallas, TX
Post Number: 6945
Buy an autoformer based speaker selector switch and place it in line.
Username: Ironhorse
Sweet Thanks. How much do those usualy run??
Username: Ironhorse
And were am I able to get them??
Dallas, TX
Post Number: 6955
Most audio shops should sell something that will get you up and running. The cost will vary with the quality of the autoformer and the amount of wattage it can handle.
Username: Frostyda9
Calgary, AB
Post Number: 106
How about....put them in series? Too easy?
Username: Nuck
Parkhill, Ontario
Post Number: 1794
Too Easy Frosty.
Two 4 ohm loads in series create an unstable return load to the amp, let alone the soak of the first speaker.
Very unstable and undesirable.
Username: Frostyda9
Calgary, AB
Post Number: 107
Looks good on paper though, no?
In any event, experimentation is good, but there are a plethora of quality active subs out there intended for home use that will without a doubt be less of hassle.
Maybe Justin will let us know what he ended up doing
Username: Nuck
Parkhill, Ontario
Post Number: 1809
Oh Justin, where art thou?
Dallas, TX
Post Number: 7986
Possibly Justin tried the series connection and passed away in the resulting fire.
Username: Nuck
Parkhill, Ontario
Post Number: 1823
hehe
Username: Nuck
Parkhill, Ontario
Post Number: 1824
Alas poor Justin, I knew him well...
Username: Nuck
Parkhill, Ontario
Post Number: 1825
Slings and arrows and fire brought on by home octopii...
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Preamps > Any 4ohm to 8ohm converters?? [ « Previous ] [ Next » ]
