Thread: Sony audio receiver problem (STR-AV570X) |
New member Username: Parker1712001
Post Number: 1 Registered: Dec-05
| Posted on Friday, December 16, 2005 - 02:49 pm: |
I moved recently and, when hooking up the old Sony tuner, discovered an interesting problem. When the tuner is plugged in (before it's turned on) it makes a clicking sound. When it's turned on, there's a blinking red "P" on the screen that renders all function inactive. Does anyone know what this could mean? I no longer have the manual. thanks!! |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 6910 Registered: May-04
| Posted on Friday, December 16, 2005 - 11:21 pm: |
"Protection"? Does is produce any sound? |
Post Number: 2 Registered: Dec-05
| Posted on Friday, December 30, 2005 - 11:57 am: |
It might stand for protection. No sound comes from the speakers, just an intermittent clicking sound from within the tuner (almost like its trying to turn itself on and off). |
New member Username: Ajparoczai
Post Number: 1 Registered: Jan-07
| Posted on Tuesday, January 23, 2007 - 03:51 pm: |
The operation manual says: A serious trouble has occurred such as overheating or short-circuiting. Refer servicing to qualified person. Check all the wires for touching. Especially the speaker cables at the receiver and the speakers. I have a similar problem. Unpluggin/pluggin back in makes it work for a couple of hours, the P again. I took all the cables out, attached one speaker and used the tuner. Same problem. Something inside is probably short-circuiting. |
