Home > Message Board > Home Audio > Amps > Archive through December 23, 2005 > Amp not powering subs
Author Thread: Amp not powering subs
stl kid
i have a fosgate 12 in sub and fosgate amp.. all brand new.. i have all of the wiring wired and there is power going to amp but when i put the speaker wire in the outputs the sub will not function. i even tried putting an extra set of speakers with different speaker wire in and still no response on that either. what gives?
Username: Project6
Post Number: 4486
If it is brand new and it is not working, then it is broken, don't you think? That's what gives!
If everything is installed right and you are positive that the amp is not working, i.e., fuses, proper grounding, etc. return it.
SpeAKerKiNG
Berny is an idiot when it comes to this stuff anyway, do not listen to him
Username: Stu_pitt
NYC, NY
Post Number: 811
Speaking of idiots, did you happen to see the part where it says CAR AUDIO on the top of the page?
Wonder why?
BECAUSE IT'S NOT THEIR!!!!
Go to the CAR AUDIO section idiots!!!
Username: Touche6784
Post Number: 807
i second that. the admin really needs to do something about these moronic anony poster. it is starting to get annoying, actually its been annoying for a while.
Home > Message Board > Home Audio > Amps > Archive through December 23, 2005 > Amp not powering subs [ « Previous ] [ Next » ]
