Home > Message Board > Home Audio > Speakers > Archive through December 27, 2005 > $100 budget
Author Thread: $100 budget
XB0XERS
i know i sound cheap but, is there any 5.1 soround sytem(with optical input) that is under $100? i have found this Curtis - 150W 5.1-Channel Home Theater System. http://www.bestbuy.com/site/olspage.jsp?skuId=7292645&type=product&productCatego ryId=pcmcat40200050002&id=1118840867407
but i hear Curtis is garbage what do i do?
Username: Dakulis
Spokane, Washington
United States
Post Number: 732
Save money for something nicer or buy the Curtis and hope it's better than all the other PC type speaker systems out there.
Durabrand? And yes, at this price point, pretty much everything would be considered garbage.
XB0XERS
fine $150 :-)
XB0XERS
I will go with these Sony Home Theater System (HT-DDW670)for $179.99
http://www.bestbuy.com/site/olspage.jsp?skuId=7136002&type=product&productCatego ryId=pcmcat40200050004&id=1110263641433
i accept donations via paypal, thankyou
Username: Nadz
Califonia
Post Number: 9
To get anyhthing remotely decnet you need to spend 300. An extra 50 bones is not going to cut it.
Username: Rsxman
Post Number: 157
just save your money or youre going to wish you got somethning better.
XB0XERS
how about book shelf or headphones (anything) under $150?
(sorry for being such a noob{i am one}but do i need any kind of reciever to go with the bookshelf?)
By the way i am using these speakers to replace my $5 10w desktop speakers so the speakers dont need to be loud just better than a $5 pair.
Username: Rsxman
Post Number: 164
bookshelf what? speakers? an actual bookshelf?
If you are just talking about computer speakers for music or gaming, Klipsch makes a very good 2.1 setup that is THX certified for about $140.
That would be your absolute best bet for some good sounding music and gaming speakers.
Home > Message Board > Home Audio > Speakers > Archive through December 27, 2005 > $100 budget [ « Previous ] [ Next » ]
