Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through May 13, 2004 > Speeker spikes
Author Thread: Speeker spikes
placing your speekers on spikes is something i just heard about and never thought of before so i looked up speeker spikes online an foung that they come in many different shapes and sizes. what i want to know it how do they help the sound , what types of floores can they be used on and what shape/size of spike should i use?
thank you
Alan
Username: Project6
Post Number: 491
its usually used for carpeted floors or if you are placing the speakers on soft materials
check this
http://www.audiovideo101.com/dictionary/dictionary.asp?dictionaryid=414
I did a quick test to see if this tecniq realy works. what i did is took a piece of thick cardbord and put some pinty scrus through it at the corners then set my speekers on them and lust from this hack job i noticed a substantal improvement in the sound
Username: Project6
Post Number: 492
well and good...now go out there and set it up
cheers
Username: John_s
Columbus, Ohio
US
Post Number: 85
Berny:
You are one of my fonts of knowledge. Thanks. My question is will spikes make any difference on carpet over a solid concrete floor, as in a basement?
cheers to you!
Username: Project6
Post Number: 499
what you are doing there is just anchoring the speakers to the concrete floor, that is, going through the carpet via spikes. What you want to happen is keep the speakers from unnecessary vibration due to its own inherent function. The only thing you want vibrating are the drivers and keep these vibrations from transferring to the speaker enclosure itself sometimes colouring the sound. Placing the speakers directly on carpet makes the enclosure unstable and wobbles unnecessarily, using spikes will stabilize the enclosures. Experiment, evaluate, listen...smile and enjoy if you get there!
here's some more reading material,
http://pkant.htmlplanet.com/speakfaq.htm#spikes
http://www.soundcare.no/faq.htm
now, beware, some of these articles are there because they are trying to sell their product, just take the information for what it is, and make your own judgement.
Username: Billdashill
Post Number: 80
Levelers!
Spikes also enables one to level their speakers if you have an unlevel subfloor.
Username: Rick_b
New york
Usa
Post Number: 174
John S,
Berny is definitely on the right track. To contol internal vibrations, and channel them from the speakers, the material of choice is brass. Brass iso-cones will control the vibrations. They make them in carpet piercing models for stability as well. I use brass isolaton cones under all my components. The best ones I have found are from Mapleshade Records @ www.mapleshaderecords.com. They are solid brass and massive. I recommend them without question. Cheers!
anon
Would spikes be helpful if speakers are placed on brick floor?
Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through May 13, 2004 > Speeker spikes [ « Previous ] [ Next » ]
