Thread: Integrated with loads of headroom for my Kappa 7's |
New member Username: Orangeclockwork
Post Number: 2 Registered: Dec-05
| Posted on Friday, December 09, 2005 - 08:31 pm: |
Hello, I'm on a mission to find the best deal on an integrated with at least 150wpc and high current capability to match my new/old Kappa 7's. It also has to have a nice MM/MC phono section. Remote would be a plus but not important. |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 6861 Registered: May-04
| Posted on Friday, December 09, 2005 - 09:47 pm: |
What do you have now and what have you considered? |
Post Number: 3 Registered: Dec-05
| Posted on Friday, December 09, 2005 - 10:30 pm: |
Never ran them cause I am starting from scratch. I know the Kappa's are power hungry. I was thinking about going with a N.A.D. but not sure how it would match and its missing a phono section. |
Dallas,
TX
Post Number: 6863 Registered: May-04
| Posted on Friday, December 09, 2005 - 11:43 pm: |
You can always use an outboard phono section. So you don't have anything else in mind? How about a budget?
denon pma 2000ae Unregistered guest |
| Posted on Saturday, December 10, 2005 - 08:59 am: |
80W + 80W (8ohm 20-20,00Hz) 160W + 160W (4ohm 20-20,00Hz) http://www.avland.co.uk/denon/pma2000ae/pma2000ae.htm |
Post Number: 4 Registered: Dec-05
| Posted on Saturday, December 10, 2005 - 10:51 am: |
Denon is nice, but out of my budget. I'm on a NAD type budget. $500-$600. I guess I'll continue checking Audiogon for something. I just missed a Bryston by a couple of days for $600 but that would mean adding a preamp so I regress, NAD? |
Dallas,
TX
Post Number: 6868 Registered: May-04
| Posted on Saturday, December 10, 2005 - 01:56 pm: |
At that price range, yes, you choices are limited to just a few lines unless you find something used as an alternative. |
Post Number: 5 Registered: Dec-05
| Posted on Saturday, December 10, 2005 - 03:30 pm: |
I was also thinking maybe Outlaw's new 2 channel receiver. I heard it has adequate headroom. This might be the course I take unless I can find a good used high end piece. Thanks |
New member Username: Nadz
Califonia
Post Number: 6 Registered: Aug-05
| Posted on Saturday, December 10, 2005 - 11:48 pm: |
Check the Outlaw.com website. They sell some 300 dollar mono blocks that put out 200 watts and should drive the Kappas easily. |
Califonia
Post Number: 7 Registered: Aug-05
| Posted on Saturday, December 10, 2005 - 11:49 pm: |
DOH !!! Youre looking for an integrated amp. Sorry. |
Post Number: 6 Registered: Dec-05
| Posted on Sunday, December 11, 2005 - 12:02 am: |
I saw those Outlaw 'pancake' monoblocks on their site the other day. Very nice and pretty incredible that they put out so much power for their size. |
New member Username: Cheapguy3
Birmingham,
AL
Post Number: 2 Registered: Nov-05
| Posted on Monday, December 12, 2005 - 10:24 pm: |
Denon receiver question: I have read a lot of good things about the Denon A/V receivers. I am trying to decide between the AVR-3806 and the AVR-4306 (musically is it worth the extra money?). Both are supposed to be very faithful in their ability to reproduce music, which is something I prize very highly in an A/V receiver since it will have to do double-duty in my home. I haven't heard either unit. Have any of you had any experience with them? Are there receivers in the same category you would recommend over the Denon products? By the way, the receiver must have HDMI inputs/outputs. Thanks for your help!
Dallas,
TX
Post Number: 6886 Registered: May-04
| Posted on Monday, December 12, 2005 - 10:53 pm: |
JB - I hate to be rude, but this is the "integrated amplifiers" section of the forum. |
| Posted on Thursday, December 29, 2005 - 10:08 pm: |
John, You may want to check out the Jolida 1501RC. It's a hybrid tube/solid state that puts out 100wpc. Considering all watts not created equal - the Jolida could do the trick. The RC version comes with a remote, and I often see them on Audiogon in the $550 range, often less. You'd need an external phono amp - but they're pretty well-reviewed, and it could do the trick! Vintage Luxman integrateds like the L-580 and some others could be a fit as well. They're known to be warm, able to push anything, and I see them on ebay often in the $300-400 range. Granted they can be tough to fix should a problem arise. As far as receivers - Luxman put out the R-117 which put out 160wpc and came with remote. Also any number of vintage receivers pack quite a bit of power. But I also know HK put out some 2-channel receivers lately like the 3480 that is 120wpc - check out Audioreview - and these things are something like $320! Just thought I'd throw out a few things to further confuse the situation! lol Best of luck, Marc |
