Home > Message Board > Home Audio > Amps > Archive through December 23, 2005 > Cambridge Audio 640A Heat Issues
Author Thread: Cambridge Audio 640A Heat Issues
Username: Blazen69
Just bought a Cambridge Audio 640A. When i play music with the volume about half way up for about ten minutes it gets hot and shuts itself off. Is this a problem with the design or did i get a lemon. I am drving Jamo E650's.They are 6 ohms and about 90 sensitivity.(not hard to drive).Can any cambridge owners comment.Do
your amps get hot also. Half way up is not that loud so i'm pretty pi*#ed off
Username: Angello
Post Number: 28
well if you didin't turn volume knob the first 10 or 15minutes to the half, then it's not your falt!
Bring it back then
Home > Message Board > Home Audio > Amps > Archive through December 23, 2005 > Cambridge Audio 640A Heat Issues [ « Previous ] [ Next » ]
