Thread: Blown Sub??? |
taylor laurence Unregistered guest |
| Posted on Thursday, December 01, 2005 - 08:22 pm: |
Hey, I own a JVC HX-Z10 minisystem, I've had it for about a year and a half and it is currently hooked up to my computer. The other day I went to play some tunes where I noticed a hissing/weezing sound from the sub on the right side. The whole stereo cuts out whenever there's a certain level of bass, so right now I've disconnected the subs. To get the sub working, I've trying connecting/disconnecting the wires, putting the right feed wires into the left one, and the speaker remains effed. I took off the side panel to check the cone, I didn't notice any cracks/tears. If the sub is blown, can I go to an audio store and simply pick up a similar sub? Or am I just screwed for bass now? Thanks. |
New member Username: Gamerdude
Kitchener,
Ontario
Post Number: 6 Registered: Apr-06
| Posted on Tuesday, April 25, 2006 - 02:26 pm: |
Sounds to like you might have screwed up ur amp up i have a old set of logitech computer speaker and the woofer is pretty much done the foam suround is killed parts of it are missing and it dosnt hiss/weezzz so i'm thinig you have over loaded you amp some how or it just is bing reatrd e-mial the company and see what they think
