Thread: Unique Set Up Needs Help ! |
New member Username: Darkulti
Post Number: 2 Registered: Nov-05
| Posted on Tuesday, November 29, 2005 - 08:27 pm: |
Hi everyone, I'm a newbie here with few knowledge of audio system. I have spent days reading information on magazines and internet, but I am still confused. Your expertise in setting up a unique audio system will be very helpful to me. I would like have an audio system to produce a sound inside and outside my small condominium, 40' W x 80' L = 3,200 Sqft. no rooms inside with 5 floors. Inside Criteria: 1. Run 24hrs - two cds producing two different natural sounds with frequency range of 1.5 KHz - 5.5 KHz output. 2. The sound inside the building should be able to reach a peak level of 100 - 120 db as rock band concerts. 3. The average room temperature is around 86 Farenhiet. My questions are: 1. Which required equipments will suit me best, Receivers, Power Amplifiers, or Integrated Amplifiers? 2. Should I purchase optional equipments? 3. Any other recommends ? All advice is appreciated. Thanks for all your kindness. |
Silver Member Username: Stu_pitt
NYC,
NY
Post Number: 770 Registered: May-05
| Posted on Tuesday, November 29, 2005 - 08:56 pm: |
Gte one of these for each area you need clean and loud music - http://www.harveyonline.com/products/details.asp?sku=265&auth=KMOJG&r=0&category %5Fid=4&subcategory%5Fid=49702&page=2&order%5Fby=a%2Emfgr%2C+a%2Emodel%2C+a%2Eti tle&mscssid=WT8JW3BX8KTR9KELC1CA4TFP88156421 |
