Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through May 10, 2004 > NAD T763 - Component Video Inputs
Author Thread: NAD T763 - Component Video Inputs
Username: Mgkaplan
Calabasas, CA
Post Number: 19
I will be picking up my NAD T763 on Tuesday. I understand that this receiver has 3 component video inputs and a component video output.
If I run all of my video sources (HD Cable, Yamaha DVD-S2300MK2 Player, and Sony 400 disk CD/DVD changer) through my receiver, will I lose video quality?
My TV has only 2 component video inputs and the 3 inputs on the receiver are looking very attractive.
Username: Gatt767
Malta
Post Number: 41
No not at all, the Components on the T763 are ready for high bandwidth pass through!
St. Louis Blues
I have the NAD T763- but haven't upgraded to HDTV yet. I use the receiver to switch sd satellite, xbox, vcr, and dvd using s-video and composite inputs with no problems.
I haven't seen the spec for bandwidth- but understand it will handle HD. Anyone verified this yet?
Username: Bigfan
Post Number: 26
the bandwidth spec on the NAD is 50 mHz. is that adequate for HD (1080i)? some other receivers have more, for ex. HK 7200 is 100 mHz, i believe. how much bandwidth does one need for HD?
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through May 10, 2004 > NAD T763 - Component Video Inputs [ « Previous ] [ Next » ]
