Thread: Need opinions |
Bronze Member Username: Bill984
Post Number: 44 Registered: Oct-05
| Posted on Friday, November 25, 2005 - 04:35 pm: |
i just bought a 43"pioneer elite hd930 and want to get martin logan clarity speakers. i need some opinions. if you have the time go to this link where i have a denon ar3806 and a Pioneer VSX-74TXVI 7.1 CH Receiver. please give opinion on which to go with and why. thanks http://www.bizrate.com/search/compare__Compare.x--54,Compare.y--10,cat_id--11070 000,pid-346368545--on,pid-353294363--on,prerd--1.html |
Gold Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 3059 Registered: Mar-05
| Posted on Friday, November 25, 2005 - 06:33 pm: |
Either will be fine, get whatever's available cheaper. Although you could get equal or better sound quality for a lot less with this little marvel: http://www.amazon.com/gp/product/B0009E1YPM/103-3152032-3370267?v=glance&n=17228 2&n=507846&s=electronics&v=glance Not as manly-looking, about 2 dozen fewer arcane connections on the back, and a lot fewer digital sound-shaping modes though. Egads, whudathunkit? |
