Home > Message Board > Home Audio > Receivers > Archive through November 30, 2005 > Yamaha 2500 front display panel lights
Author Thread: Yamaha 2500 front display panel lights
Username: Sm8224
I just purchased this 2500, and when i first plugged it up, the front panel display lights were shutting off after about 30seconds, which i found to be a cool feature for watching movies. After complete set up, i noticed the lights are no longer timing out and shutting off. Where is the setting to make them shut off again? thanks in advance.
Username: Kano
Post Number: 764
I don't have your receiver, but with my HK the option is in the OSD, and must be done on screen through a composite or s-video connection. The HK also has a dim button to do it manually.
Home > Message Board > Home Audio > Receivers > Archive through November 30, 2005 > Yamaha 2500 front display panel lights [ « Previous ] [ Next » ]
