Thread: Optical audio inputs/Denon Receiver |
New member Username: Maxtrane
Post Number: 1 Registered: Nov-05
| Posted on Tuesday, November 22, 2005 - 11:05 pm: |
I have a Denon AVR4800 and it has 5 separate optical audio inputs. I'm having trouble getting audio from a Dvd player. I've tried 2 sets of optical cables. I have gone through the denon on screen menu and have corrrectly choosen the digital audio assignment. in fact, i've tried all 5 inputs. i've tried another dvd player as well with the same results. Is there another step that i'm missing? i've been through the Panasonic DVD setup menu as well as the denon menu several times. |
Bronze Member Username: Paul98
Post Number: 87 Registered: Oct-05
| Posted on Tuesday, November 22, 2005 - 11:50 pm: |
You will most likely need to set the input that you want to accept digital input. You are also going to have to assign the digital input to corrispond to the correct option. I don't have that receiver but those are a couple things to look at. |
Post Number: 2 Registered: Nov-05
| Posted on Wednesday, November 23, 2005 - 08:34 am: |
Thanks for your input. I have correctlty assigned the digital input using the denon on screen menu. I have had success assigning the coax input for my cable box and i'm getting digital audio for that. I guess its possible both optical cables are bad. |
Silver Member Username: Chitown
Post Number: 478 Registered: Apr-05
| Posted on Wednesday, November 23, 2005 - 12:30 pm: |
Try hooking it up with the normal RCA pair. If you are get sound from it, then you are missing the setup either on the Denon side or the Panny side.
Post Number: 3 Registered: Nov-05
| Posted on Thursday, November 24, 2005 - 09:36 pm: |
Yeah, i tried that and i do get audio with the rca cables. I called and spoke to someone at denon and they said that maybe the optical inputs are bad. They suggested a shutdown of the Receiver and a re-boot to factory setting to see if that might help. The coax dig inputs do work and i would just that, but my Panasonic DVD does not have a coax output. Crazy in this day and age. |
Silver Member Username: Rysa4
Post Number: 115 Registered: Jul-05
| Posted on Thursday, November 24, 2005 - 10:57 pm: |
Not really. Its more expensive to put a coax output jack in than a digital output jack. So it makes perfect sense in this day and age. |
