Thread: NAD T163 NO OSD |
Puzzled05 Unregistered guest |
| Posted on Tuesday, November 22, 2005 - 09:34 am: |
I can't get the On Screen Display on my T163 to work. I have it connected to the TV via RCA video cable. I know the cable & TV are OK because I hooked up my VCR video out and it worked fine. All I get is a blank screen. Is there some setting I'm missing? Thanks for any help! |
Relevant Product Info
New member Username: Paradigm2200
Campbell river,
Bc
Post Number: 2 Registered: Dec-05
| Posted on Monday, December 12, 2005 - 05:54 pm: |
sorry, i do not have an answer for your question, because i haven't bought mine yet.. sorry!! but maybe you can answer my question. do you have the t973 power amp also, if so how do you like the combo? |
New member Username: Mikehdtv
Post Number: 1 Registered: Mar-06
| Posted on Sunday, March 19, 2006 - 01:17 pm: |
use the s-video out |
New member Username: Dakaalda
IL
Post Number: 3 Registered: Apr-06
| Posted on Monday, May 01, 2006 - 03:16 pm: |
Puzzled05. You say that you hooked up your vcr out and it worked. If you are using video 3 or 4 for your vcr and trying to see osd thru one of those outputs, it will not work. They are for monitoring only. The osd is not output on the component outs either. using the s-video is a good idea like rob said but rca should work as well. Hope this helps. |
New member Username: Jdub555
Calgary,
Alberta
Post Number: 3 Registered: Jan-08
| Posted on Friday, February 08, 2008 - 12:07 pm: |
I have the T163 and there is a dedicated "monitor out" rca connector to go to your TV/monitor. That being said my monitor out and VFL display have now both failed/intermittent operation. Have been told it is a loose connection on video card. have not repaired or sent out as yet cheers |
