Thread: Cambridge audio help... |
New member Username: Joemuers
Post Number: 1 Registered: Nov-05
| Posted on Sunday, November 20, 2005 - 05:58 pm: |
hi there one & all, I have a cambridge a300 amp which i recently got fixed at a local repair shop. Thing is, it does't sound the same to me, in fact it sounds decidely dodgy. Is there any way I can check if they've ripped me off by using cheap, crappy replacement transistors instead of the 'proper' ones?? If there is, would be really helpful to know, otherwise just my word against theirs, you know? cheers to anyone who can help me out |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 6646 Registered: May-04
| Posted on Sunday, November 20, 2005 - 06:05 pm: |
Call Cambridge. |
Post Number: 2 Registered: Nov-05
| Posted on Sunday, November 20, 2005 - 06:08 pm: |
they don't have a contact number, they only deal through Richer Sounds in the UK so unfortunately can't do that.. |
Silver Member Username: Nuck
Parkhill,
Ontario
Post Number: 446 Registered: Dec-04
| Posted on Sunday, November 20, 2005 - 08:02 pm: |
did you get the 'repaired or replaced' parts back? Did you ak for them? |
Dallas,
TX
Post Number: 6651 Registered: May-04
| Posted on Sunday, November 20, 2005 - 08:57 pm: |
Who did the repair? |
