Home > Message Board > Home Audio > Amps > Archive through December 23, 2005 > NEED HELP Bad!!!!
Author Thread: NEED HELP Bad!!!!
Username: Audiowizard69
Post Number: 12
i have a little 80 watt amp to power an 8 inch woofer in my bedroom and i have tryed all kinds of power supplies. all i get is a humming noise from the sub. i even bought a noise filter and put on it but it helps nothing... If anyone knows how i can fix this please let me know.
Username: Project6
Post Number: 4293
Are you using a car amp? What is the amperage rating of your power supply? Is the amp grounded to the power suppky?
Username: Project6
Post Number: 4294
oops, I meant power "supply"
Post Number: 15
3 amp rating and it is grounded to the power supply
donal
ive just blew my ashdown electric blue 180 bass amp,is there some way u can tell with a battery that ur amp is defently blew?
Username: Project6
Post Number: 4298
Audio Wizard,
You need a lot more than 3 amps. You have to match or exceed the ampere rating of the vehicle. Try and get a power supply that is rated at 30 amps.
Home > Message Board > Home Audio > Amps > Archive through December 23, 2005 > NEED HELP Bad!!!! [ « Previous ] [ Next » ]
