Home > Message Board > Home Audio > Amps > Archive through December 23, 2005 > NAD C162/C272 Problems!
Author Thread: NAD C162/C272 Problems!
Username: Bcollins
Rockport, MA
United States
Post Number: 12
Had to return my new NAD's. Was getting static/hiss through speakers with volume all the way down. Also, low level music still comming through when volume all the way down. Could get it to stop temporarily by moving pre-amp around a few inches in different directions in relation to amp. Has anyone else had this problem? Spoke with NAD tech support, did some trouble-shooting, switched cables, sources etc. but could not fix. Did not have problem through headphone jack however. Technician recommended returnig for replacement since it was still within the dealers 30 day return policy. Would like to get replacement but don't want to go through another return if this is a wide-spread issue. Any feedback would be appreciated. Thnk you,
Bill
Username: Nuck
Parkhill, Ontario
Post Number: 421
Sorry to hear, Bill.
But if it's gonna go wrong, better now than later.
You will get fixed and enjoy.
Pennance for being a bad boy?
Haha.
I'tll work out
Username: Bcollins
Rockport, MA
United States
Post Number: 13
Thanks for the sympathy Nuck. You're right, "better now than later". Are you aware of any reliability problems with NAD? I thought they were supposed to be of good quality, but I've seen a couple of references on this forum indicating some problems with reliability. I realy like the sound, so I hope to replace the returned units, but I don't want to get into a situation where I am repeatedly sending them in for repair.
Bill
Username: Artk
Albany, Oregon
Post Number: 2265
I have the C162 and it's been a stellar performer. The QC issues that I have seen and fallen prey to are with the AVR's. Never had a bit of trouble from their 2 channel components.
Username: Bcollins
Rockport, MA
United States
Post Number: 14
Thank you Art. The reports I'd heard of were not specific, so I wasn't sure which models they refered to. Thanks again,
Bill
Username: Nuck
Parkhill, Ontario
Post Number: 427
One time thing, Bill, for sure.
I'tll all pan out pretty quick, and life is good.
Patience grasshopper(or some shite like that)
Peace
Rantz
Bill,
Have had the C162/272 combo for three days now playing almost constantly - no problems whatsoever in fact I believe it is worth every cent. The silence when the music pauses is ink black and the sound coming through the 602S3's is outstanding. These things have been out for a while now so if there was any abnormal number of problems I'd think we know about it from the forums.
Get a new one and enjoy.
Username: Unbridled_id
Chicago
Usa
Post Number: 122
" low level music still comming through when volume all the way down". That sounds like an issue with the pre, perhaps a relay ? I own the c272, also a 541i and c422, not a problem and the
sound coming out of my polk lsi-9's is warm and smoooooooth.. Like the others have said, better now than later, get replacements and rock on...
Username: Artk
Albany, Oregon
Post Number: 2271
Congrats on the new gear Rantz.
Username: Nuck
Parkhill, Ontario
Post Number: 436
Enjoy Rantz, and tell us all about it!
Username: My_rantz
Australia
Thanks Art/Nuck. We're lovin it. Will report thoughts soon - so far they're all good.
Username: Jan_b_vigne
Dallas, TX
Post Number: 6645
My Rantz
Username: My_rantz
Username: My_rantz
Australia
Well seeing as how everyone was complaining about unregistered users :-)
Username: Nuck
Parkhill, Ontario
Post Number: 444
He's baaaack
Username: Nuck
Parkhill, Ontario
Post Number: 445
You old dog?
Username: Artk
Albany, Oregon
Post Number: 2277
Great to see ya registered again MR.
Username: Danman
QUEBEC
CANADA
Post Number: 589
First of all, low level sound with the volume all the way down is normal. I asked and checked other brands and they all due this do to the high current. As for your problems, I find this rare but it can happen. I owned Hondas and Toyotas all my life until recently buying Mazda and it has been the most trouble free car I have evr owned! This is not a NAD issue but more bad luck than anything! I am sure when you change them, all will fall into place.
Dallas, TX
Post Number: 6657
Do to high current? There should be no current without a signal. This would indicate a problem of poor switching to me. Are these units with mechanical or electronic switching?
Username: Danman
QUEBEC
CANADA
Post Number: 590
Boy, I sure put my "due's" and "do's" backwards!!!!!!
What I meant was that I have asked this question of low level sound even when the volume is at a complete 0 and noticed this happens with many brands that are mid or higher fi. I am no technician but I have a friend that owns 50000$ of YBA gear that does the same! He said it was because of high amperage or something of that nature! Please don't quote me but I have heard other brands do this since my NAD gear has always done the same even after 1 1/2 of ownership problem free.
Username: Bcollins
Rockport, MA
United States
Post Number: 15
Thanks for the feedback everyone. Just to clarify, when I moved the pre-amp around in various directions above the power amp the static hiss would go away as would the low level sound and the peakers would then be dead quiet-no sound at all. If I moved it again or even just left it alone, eventually the static hiss and low level sound would return. It all depended on the postion of the pre-amp in relation to the power amp. This did not happen for the first week or two after I bought the NAD's.
Bill
Username: Danman
QUEBEC
CANADA
Post Number: 591
That is very strange! Mine never did this and I know others that have them without this problem. Don't worry, when you get new ones this will all go away.
Username: Sun_king
Leeds, West Yorkshire
UK
Post Number: 300
I've been running a C160/C270 pair for over a year with no such problem. Also had the C162/C272 set for a week or so, again with no problem. Perhaps you had a duff piece of equipment. What leads did you connect between pre & power? Do you have your hifi near to any electrical devices that could cause interference? You are supposed to locate the pre-amp as far away from the power amp as is possible, ie not have them stacked directly on top of one another. This is to make them as un-combo like as possible (the whole point of having separates is to keep the power supplies apart) - you want to get the full benefit of having separate boxes. Having said that, that still shouldn't create the problem you describe.
Username: Nuck
Parkhill, Ontario
Post Number: 479
http://www.dvdtimes.co.uk/images/KarlWareham/looneyv2_10.jpg
Ya think.
Didnt see that in the manual or in the literature. Or with the 3 foot leads.
Username: Nuck
Parkhill, Ontario
Post Number: 480
I have no idea how the pic got there, folks.
Sorry
Doh!
It was cut hours ago!
Username: Nuck
Parkhill, Ontario
Post Number: 481
But thats me alright.
Username: Nuck
Parkhill, Ontario
Post Number: 482
King, the discrete power of the pre will(should) not be able to influence any other circuit, especially one a s heavy as the amp.
However, a poorly insulated coil in teh torroidal could influence the pre, although those circuits are pretty well off frequency with anything else.
But sometimes its plug in and find out, i suppose.
Home > Message Board > Home Audio > Amps > Archive through December 23, 2005 > NAD C162/C272 Problems! [ « Previous ] [ Next » ]
