Home > Message Board > Home Audio > Receivers > Archive through November 30, 2005 > Kenwood a/v help?
Author Thread: Kenwood a/v help?
Kenwood a/v surround receiver vr-414 kam-1 power amplifier circutry.... the only imput that i can make work is annalog. how do i get digital? the surrond sound doesn't work well eithor is it set up or wiring or equipment?
i hit overload at low volumes with surrond sound on
Username: Project6
Post Number: 4292
An overload? Are you using 4 ohm speakers?
Did you check the manual on how to set up for surround sound?
Home > Message Board > Home Audio > Receivers > Archive through November 30, 2005 > Kenwood a/v help? [ « Previous ] [ Next » ]
