Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through May 13, 2004 > Bridging 2 speakers to a amp how?/...
Author Thread: Bridging 2 speakers to a amp how?/////
Username: Titansrule001
2 channel amp 2 speakers forgot how the wiring go amp-L+ amp-r- right speaker- left speaker + then do i run one wire from left speaker to right sreaker ??? please tell me if i got it right.
Username: Robertinchico
Post Number: 31
Do you mean you want to Bi-wire your speakers because your amp has FOUR output terminals? Don't just start crossing and interconnecting wires between amps and speakers.
Post Number: 7
Just wanted to know how to bridge my speakers to my amp. I have two one thousand watt woofers and a sixteen hundred watt two channel amp. Seems like it should be louder than it it. The amp is bridgable and just wondered how to do so or how to get more watts out of it. Thank you.
Username: Taito
Adelaide, South Australia
Australia
Post Number: 8
VERY IMPORTANT:
Before you play with speaker conections, you need to know that you should NEVER, UNDER ANY CIRCUMSTANCES, connect the red and black speaker terminals directly together (ie. NEVER short them). The result of this would likely be the destruction of the output devices within you amp, effectively destroying it.
I would recommend going to your local hifi store and asking for their advice, but also remember that sheer power output doesn't necessarily equal volume. Factors such as speaker efficiency must also be considered.
Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through May 13, 2004 > Bridging 2 speakers to a amp how?/... [ « Previous ] [ Next » ]
