Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through May 10, 2004 > Sony STR-DA2000ES
Author Thread: Sony STR-DA2000ES
Username: Woodcarver
just puchased a Sony STR-DA2000ES receiver and would like your opinion on what speakers would go best with this receiver? thanks for the info
Username: Johnny
Missouri
Post Number: 277
David,
I listened to the 2000 paired with some PSB Image series speakers and the sound was surprisingly good. I had always heard that Sony receivers were very harsh and bright sounding (which the lower "non ES" models definately are), but paired with the warm PSB's, most of this brightness was tamed. I found that I enjoyed the music sound of the ES/PSB combo more than I did the movie sound...although the movie sound was very capable as well...just not as good as some others I have heard.
I recommend you check out this combo. For the money, PSB Image series speakers are very hard to beat. I would also check out Paradigm. Sonically, they are very similar to PSB and in my opinion would also sound very good with your new 2000ES.
Let us know what you decide on!!
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through May 10, 2004 > Sony STR-DA2000ES [ « Previous ] [ Next » ]
