Home > Message Board > Home Audio > Receivers > Archive through November 30, 2005 > Can a Marantz reciever handle a 4 ohm...
Author Thread: Can a Marantz reciever handle a 4 ohm load
Username: Taderbutt
Oregon
United states
Can a Marantz 4120 reciever handle a 4 ohm load from a set of paradigm 9se mkII's?? Is a better reciever needed one that could support a 4 ohm load better?
Username: Taderbutt
Oregon
United states
Just got the Paradigms wondering if another reciever is needed?
eventually am going to upgrade to a multi channel any sugestions??
Username: Jan_b_vigne
Dallas, TX
Post Number: 6531
What does your owner's manual suggest? Is there any information on the back of the receiver regarding impedance load?
Username: Taderbutt
Oregon
United states
Dont have the manual bought it used any extra info would be nice ill look on the back thanks
Username: Chitown
Post Number: 434
You can e-mail Marantz and see if they will send you a pdf version of this manual.
Username: Fps_dean
Williamstown, MA
Post Number: 117
The PM7200 says use at least 8 ohms for a single speaker and 16 for two (i dont know if that means 2x8 in serial or what though).
Check marantz.com they may even have manuals online.
Home > Message Board > Home Audio > Receivers > Archive through November 30, 2005 > Can a Marantz reciever handle a 4 ohm... [ « Previous ] [ Next » ]
