Home > Message Board > Home Audio > Mini Systems > Advice,comments, using wall mount RV ...
Author Thread: Advice,comments, using wall mount RV stereo in house
Username: Bed332004
I'm looking for a similiar unit for my house.
Anyone know of one? Could this be used with a DC converter?
http://www.b2loud.com/items/item196.htm
Username: Truck3rb0y
Atlanta, GA
I saw a similar 12 volt tv unit a year ago tried to do the same thing. My friend told me it wasn't a good idea.
So I guess my question is, why do you want to do this?
There are plenty of units which you can find on ebay that are inexpensive and will work without the need or complications of converting the aforementioned unit with a DC Converter. Let me know if you need finding them or if there is anything further I can do to answer your question.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Mini Systems > Advice,comments, using wall mount RV ... [ « Previous ] [ Next » ]
