Thread: JM Labs |
New member Username: Thomask
Post Number: 1 Registered: Oct-05
| Posted on Friday, October 28, 2005 - 12:56 pm: |
I have JM Labs Electra 906 Anniversary edition with the Beryllium tweeter. Does anyone have a suggestion for a decent receiver. Currently I have them on B&K Pre-amp and amp, but want to move that to a different system. |
Silver Member Username: Kano
Post Number: 715 Registered: Oct-04
| Posted on Saturday, October 29, 2005 - 12:56 am: |
2 channel only? Music or movies? |
Post Number: 2 Registered: Oct-05
| Posted on Saturday, October 29, 2005 - 01:44 pm: |
2-Channel Music only |
Silver Member Username: Danman
QUEBEC
CANADA
Post Number: 581 Registered: Apr-04
| Posted on Friday, November 04, 2005 - 09:20 am: |
YBA or NAIM sound absolutely wonderful with JM's. By the way, those are very nice speakers. |
Gold Member Username: Artk
Albany,
Oregon
Post Number: 2152 Registered: Feb-05
| Posted on Friday, November 04, 2005 - 11:10 am: |
Depending on your budget the Audio Refinement gear is a good buy. It gives you most of the performance of YBA at considerably less cost. Audio Refinement is by YBA and next year will carry the YBA name. The only receiver that I know of that would do your speakers justice is the Magnum Dynalab at 3k. |
Post Number: 3 Registered: Oct-05
| Posted on Friday, November 04, 2005 - 02:23 pm: |
I looked at the Classe CAP 151 but this used unit was snatched away before I could get it. Also Naim, Arcam, Moon. Magnum is supposed to be great. Thanks for the YBA tip. will have a look. |
Post Number: 4 Registered: Oct-05
| Posted on Monday, November 07, 2005 - 04:49 pm: |
last weekend I listened to Naim, Arcam, Moon and Magnum Dynalab. Only the Moon I-3 was a bit disappointing. I ended up buying the Dynalab receiver. Thanks for the advice. |
