Thread: WHAT SPEAKERS TO BUY |
| Posted on Tuesday, October 25, 2005 - 11:12 pm: |
Any suggestions on what speakers to buy for a SONY STRDE897 receiver. A friend recommends polk audio. I read that Energy is also good. Any suggestions?
| Posted on Tuesday, October 25, 2005 - 11:23 pm: |
They're both good speaker manufacturers, as are many others out there (Paradigm, Ascend, PSB to name a few). The right answer is what sounds best to you and fits your budget. No matter what you buy, you'll be limited by that Sony receiver. You should have come looking for advice before buying it. |
| Posted on Tuesday, October 25, 2005 - 11:35 pm: |
I'll look into those speakers you mentioned. Thanks. |
| Posted on Wednesday, October 26, 2005 - 04:37 am: |
I have Polk Monitor 70's as main speakers and love them. Im not familiar with the Sony. I have them hooked up to Pioneer and for the money am very happy with them. |
Gold Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 2719 Registered: Mar-05
| Posted on Wednesday, October 26, 2005 - 11:18 am: |
bongot, As long as you are set on keeping the Sony, I would not spend a whole lot of money on the speakers because they will never perform to their full potential. A good sub on the other hand is fairly independent so I would not scrimp on that. Here's what I'd get in your shoes: Athena AS-B1s, 2 pairs for $200 Athena AS-C1 center channel, $100 from audioadvisor.com Hsu STF-2 subwoofer, $425 shipped or $350 shipped B-stock from hsuresearch.com
Silver Member Username: Cheapskate
Post Number: 485 Registered: Mar-04
| Posted on Friday, October 28, 2005 - 07:50 am: |
if you're using a sony reciever... i'd suggest avoiding any speakers described as polite in the treble. to my ears, sony recievers sound too polite themselves and could stand some brightening. if you don't mind doing some homework, i'll paste this list of speaker brands known for "bang for the buck" along with a few reviews of different models in different sizes for you to ponder. it isn't a definative answer, but there are alot of great speakers out here for reasonable prices from these manufacturers. canadian speakers in particular seem to offer alot of bang for the buck. value speaker brands: canadian: ............................................ axiom paradigm psb energy mirage ............................................ aperion NHT epos wharfdale infinity polk boston acoustics cambridge sound works ascend definative technology pinnacle specific models & reviews: Axiom Audio Millennia M40Ti $275 floorstander http://www.soundstage.com/revequip/axiom_millenniam40ti.htm Paradigm Esprit v.3 $400 floor stander RAVE http://www.goodsound.com/equipment/paradigm_esprit_v3.htm Pinnacle Classic Gold Reference $900 list wins a shootout vs. B&W, Monitor Audio & Paradigm http://www.audioholics.com/productreviews/loudspeakers/faceoff2.php Wharfdale Diamond 9.6 $800 tower gets a rave http://www.theabsolutesound.com/newsletter/153/wharfedale.html Stereophile magazine really liked the $320 Epos ELS-3 minimonitors and rated them "class-c" over speakers 3 times their price. the last speaker i mentioned was magnepan MMGs, but i wouldn't trust them on a sony as they're 4 ohm loads and most japanese don't like 4 ohms. |
New member Username: Fps_dean
Post Number: 6 Registered: Oct-05
| Posted on Tuesday, November 01, 2005 - 08:12 am: |
I will suggest Infinity Beta 50s. They typically run about $500 a piece and they really sound like they should run $1000 a piece. You can get a pair for $730 or so on ebay after shipping so go to your local store and check them out. They are a very natural sounding speaker. They have deep lows but not overpowering lows without cranking the bass up. Polk's are too bright for my liking. |
