Home > Message Board > Home Audio > CD Recorders > I need help with the BOSS BR-900 CD 8...
Author Thread: I need help with the BOSS BR-900 CD 8-track
I've made original drum patterns, ok? but the drums don't stop, they just keep repeating. There dosn't seem to be an explination in the manual. help, please.
Relevant Product Info
Billybonus
Patterns or arrangements?
With arrangements just insert a break at the end (it repeats the last phrase over and over)
With Patterns I guess just leave a load of silent phrases at the end.
I am having problems too. Can you start recording drums patterns (in real time) at any point in the song? Mine goes straight back to the beginning. V annoying.
Username: Boldbassic
London
Uk
i need help with this whole dam product its not as easy as it was being sold how do yo record bass drums guitars can you please guide me thru this as the dvd manual looks good but expensive thanks heaps
Username: Daphnebossbr900
England, UK
UK
I think the bass guitar, you just plug in on the 1st socket at the back, facing the machine it is the left hand side where it says guitar1/bass, I think. Then choose which track you want to use.
I have just come to find out that my pc doesnt recognise it so there fore I cannot whip the files off the Boss onto my pc, grrrr. I did manage to produce a cd with a song of mine on it but I hadnt mixed it down properly, it did work though as I burned V78 track which is all the mixed stuff together, but I found the volume not as loud.
As for drums, I cheat, I used the rythmn on my keyboard as you can record the keyboard itself with the rythmn, therefore the timing etc is bang on also. Casio keyboards have good rythmn patterns also.
Hope I have been a bit of a help and if anyone can help me on the pc thing please fire away.
Ta.
Daff xx
Username: Stumiller00
I am having trouble with the br900cd V2.I plug the guitar in where it says guitar/bass select a track then press record and play bt there is no sound coming from the machine when I play the guitar and there is no sound when I play back a recording.What im recording.what am I missing.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > CD Recorders > I need help with the BOSS BR-900 CD 8... [ « Previous ] [ Next » ]
