Home > Message Board > Home Audio > DAT > Help!! Denon DCM 380 cd player pro...
Author Thread: Help!! Denon DCM 380 cd player problem
Username: Blake1
Any advice out there for me RE Denon cd player ? Unit is only 6 months old and has been working fine. Out of the blue, it just does not play a disc. There are a couple of discs in the player from last time it was used and when I turned the unit on, the screen just displays a "ERR" message. No changer sounds at all. No other commands seem to work. The screen read-out does cycle through the disk numbers, but after a few seconds the "ERR" message always appears. Any suggestions appreciated.
Username: Project6
Post Number: 7804
DAT?
Username: Project6
Post Number: 8251
error codes
Username: Ustaad_hc
Post Number: 697
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > DAT > Help!! Denon DCM 380 cd player pro... [ « Previous ] [ Next » ]
