Thread: Cerwin Vega Sound? |
| Posted on Tuesday, October 11, 2005 - 05:40 pm: |
Just got a small "credit" from a local (not in the US) audio store shutting down business and the guy owns me some money, the only way I can get my money now is by taking one of these all of them are 3 way foloorstanders (not towers) and they are from display: Cerwin Vega 10" KLH 12" JBL 10" I'm looking for the better sound quality out of the 3 I know the Cerwins are a bit harsh, would you guys consider Cerwin Vegas as good sound quality speakers? Generalizing out of the 3 which would be better? Thanks
Silver Member Username: Dakulis
Spokane,
Washington
United States
Post Number: 595 Registered: May-05
| Posted on Tuesday, October 11, 2005 - 07:24 pm: |
Model #s would really help as each of these manufacturers make several speakers with those general woofers, which I suspect is what you're talking about with the inch measurements? |
Silver Member Username: Gavincumm
Post Number: 243 Registered: Feb-05
| Posted on Wednesday, October 12, 2005 - 06:06 pm: |
sure, if you want frat house type party sound. That is roughly all they are good for. Not at all a hifi speaker... same goes for KLH. |
| Posted on Thursday, October 13, 2005 - 12:22 am: |
are KLH generally better than JBL? |
Silver Member Username: Rsxman
Post Number: 108 Registered: Jul-05
| Posted on Thursday, October 13, 2005 - 12:41 am: |
no klh are worse than sony and alittle worse than bose. Out of all of those I would go with JBL without question. |
Post Number: 4124 Registered: Dec-03
| Posted on Friday, October 14, 2005 - 02:11 am: |
Pink F, Have you listened to any of these speakers? Only you can make the judgement if you like the sound or not. You may even prefer the sound of KLJ, in the end, you are the one that will live with the choices. Listen to them by using the music or material you like, then choose. |
Post Number: 4125 Registered: Dec-03
| Posted on Friday, October 14, 2005 - 02:12 am: |
Pink F, Have you listened to any of these speakers? Only you can make the judgement if you like the sound or not. You may even prefer the sound of KLH, in the end, you are the one that will live with the choices. Listen to them by using the music or material you like, then choose. |
