Thread: Denon 2106 - Powerful Enough? |
New member Username: Jbrhee
Torrance,
CA
Post Number: 1 Registered: Oct-05
| Posted on Monday, October 10, 2005 - 11:03 am: |
I recently ordered a Denon 2106 receiver for some audio equipment, but now I'm having doubts that it may not be powerful enough to power what I have. I'm new to audio equipment so I don't know how powerful a receiver I need to get to power speakers with a high RMS. Please help if you can. The specs. on the Denon 2106 is 100 watts per channel and here is the equipment I'm using: -2 JBL E90 Tower Speakers, says the RMS is 225W -1 JBL EC35 Center Channel Speaker, not sure what the RMS is -1 JBL E250P 12" Subwoofer, not sure about wattage -4 JBL HTI6C In-Ceiling Speakers 100w max power Thanks for the help guys |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 6085 Registered: May-04
| Posted on Monday, October 10, 2005 - 12:58 pm: |
100 watts of Denon receiver power should be enough for the equipment you presently own. |
been200mph Unregistered guest |
| Posted on Monday, October 10, 2005 - 08:48 pm: |
Denon's ratings are quite honest. I have the 2105 powering up Klipsch Reference series speakers and could not be happier. The 2106 is the new incarnation of that level of Denon receiver. |
Silver Member Username: Riches1
Atlanta,
GA
US
Post Number: 185 Registered: Apr-04
| Posted on Thursday, October 13, 2005 - 08:59 pm: |
You'll be fine with the 2105. |
