Home > Message Board > Home Audio > Speakers > Archive through October 15, 2005 > Speaker Decisions
Author Thread: Speaker Decisions
Username: Elric6666
Hi All,
I am putting together a new surround system. I need to stay low profile (In-wall or on-wall). My receiver is the Harmon Kardon AVR 7300. I went to Harvey's and listened to the Martin Logan Fresco. They were the best sounding low profile (in wall or on wall) I had heard. I am guessing they should power well with my AVR. I would buy three as L,C,R. I would still need rear fill for HT only.
Music type is Techno/Alternative. TV (Plasma),DSS is HD HT.
Receiver stats:
Stereo Mode Continuous Average Power (FTC) per Channel : 125 Watts per channel @ <0.07% THD, 20Hz – 20kHz, both channels driven into 8 ohms
Seven-Channel Surround Modes, Power per Individual Channel : Front L & R Channels : 110 Watts per channel @ <0.07% THD, 20Hz – 20kHz into 8 ohms \
Center Channel : 110 Watts @ <0.07% THD, 20Hz – 20kHz into 8 ohms
High Instantaneous Current Capability (HCC) : ±75 Amps Input Sensitivity/Impedance Linear (High-Level) : 200mV/47k ohms
Signal-to-Noise Ratio (IHF-A) : 100dB
Frequency Response at 1W (+0dB, –3dB) : 10Hz – 100kHz
Question is - is there another low profile speaker that can deliver as good or similar response for less? If not, I will buy the Logans and call it a day.
Username: Jan_b_vigne
Dallas, TX
Post Number: 6002
Call it a day.
Username: Danman
QUEBEC
CANADA
Post Number: 571
YUP!!!!!
Username: Frank_abela
Berkshire
UK
Post Number: 933
Have a listen to M&K's Xenon system. It's an awesome sound from very small satellites and compact sub (preferably the MX700). You get a full frequency response right down to 20hz and up to 35khz. Brilliant package, if not cheap.
I'm going to buy one as soon as I have the readies...
Regards,
Frank.
Username: Elric6666
I went and listened to a few more setups today. The only in-wall or on-wall speaker that was close (IMHO) was the Triad in-wall. The Triad, however, was $3,000 per speaker vs $1,000 for the Logan Fresco. Sounds like Jan and Danman are down with the speakers. Also a note, I heard a complete 7.1 in-wall Boston Acc system and was not impressed - no comparison for a similar price. I will have a listen to the M&K though. Thanks for everyone's help!
One more thought, I have found the Fresco on-line for $630 from an outlet dealer. Is it ok to buy on-line or am I better off buying from Harvey's?
Username: Ziggyzoggyoioi
Outside Philadelphia, PA
Post Number: 151
JJ... depends how important a warranty is to you... go here and click on the red warning in the middle of the page:
http://www.martinlogan.com/cgi-bin/dealer_locator.pl
Home > Message Board > Home Audio > Speakers > Archive through October 15, 2005 > Speaker Decisions [ « Previous ] [ Next » ]
