Thread: Speaker placement in L room |
Bronze Member Username: Marica
Post Number: 13 Registered: Sep-04
| Posted on Friday, September 30, 2005 - 01:18 am: |
Where should I set 2 speakers (stereo), in L shaped room. Thank you |
Gold Member Username: Dmwiley
Post Number: 1212 Registered: Feb-05
| Posted on Friday, September 30, 2005 - 08:08 am: |
Marica, your question is too broad to definitively answer. Where is your primary listening post? What type of speakers? What type of bass response are you seeking? These are just a few questions that must be addressed. The MOFO has spoken. |
Post Number: 15 Registered: Sep-04
| Posted on Friday, September 30, 2005 - 09:49 am: |
Actually I need sound as evenly distributed all over the room as possible. I'm aware that this leeds to many compromises, but those are my priorities. I need just a simple rule for placing 2 speakers in such a room. |
Post Number: 1213 Registered: Feb-05
| Posted on Friday, September 30, 2005 - 10:00 am: |
Room dimensions? The MOFO inquires. |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 5898 Registered: May-04
| Posted on Friday, September 30, 2005 - 10:03 am: |
Put "Speaker Placement" into a search engine and you will get several set up possibilities. These are all meant to get the best performance out of the system. Even distribution depends more on the loudspeaker design than it does placement alone. Most rooms are fairly reflective when it comes to sound and too much distribution is often what you have to control.
Silver Member Username: Frank_abela
Berkshire
UK
Post Number: 922 Registered: Sep-04
| Posted on Friday, September 30, 2005 - 10:51 am: |
Marica, it's usually on the wall with the longest dimension. That said we usually describe the location of the speakers in relation to your main listening position. The relationship is such that the speakers should be set apart by a distance less than or equal to the distance of each speaker to your listening position so you form an isosceles triangle (or an equilateral triangle in the case the distances are equal). Once this triangle is maintained you will get the best reproduction for your favourite listening position. However, room reflections affect how the sound is propagated in the rest of the room. If the speakers are placed on the longer wall, then they have less reflections from side walls interfering with the sound, and the distance travelled by all the sound is lower, giving a more uniform soundscape generally. I hope this helps... Regards, Frank. |
Post Number: 1217 Registered: Feb-05
| Posted on Monday, October 03, 2005 - 07:48 am: |
Frank, that's why I sought dimensions. Both legs of L could be equal or unequal. The MOFO has spoken. |
