Thread: Please help me |
New member Username: Bman41391
Post Number: 1 Registered: Sep-05
| Posted on Wednesday, September 28, 2005 - 10:49 pm: |
can someone help, im 14 and i just got some great speakers.My receiver on the back say 120 watts max. on my speaker it say recomended receiver 120 watts. i have two speakers, do you add the watts and if you do is it safe to still hook up the speakers to the receiver?and also the speakers say that the independense is 8 omhs,but the receiver has no information about independence.i cheaked the back for a switch or if it would say it but it didn't.the receiver is old as hell.please help me. |
Bronze Member Username: Rsxman
Post Number: 57 Registered: Jul-05
| Posted on Wednesday, September 28, 2005 - 11:00 pm: |
i think it means 120 watts max per channel, what kind of receiver is it and whats the model number so we can tell you. |
Post Number: 2 Registered: Sep-05
| Posted on Thursday, September 29, 2005 - 12:19 am: |
Well its REALLY old got it from my dad its a sanyo 4 channel dcx 2700k |
Post Number: 3 Registered: Sep-05
| Posted on Thursday, September 29, 2005 - 12:23 am: |
if its not 120 watts per channel would it do any damage to my speakers or my receiver? |
Gold Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 2280 Registered: Mar-05
| Posted on Thursday, September 29, 2005 - 12:42 am: |
Only way is if you crank the receiver up past the point when distortion starts to set in on the speakers. Never heard of a receiver that COULDN'T drive 8 ohm speakers. |
Post Number: 66 Registered: Jul-05
| Posted on Thursday, September 29, 2005 - 12:46 am: |
Do you know what the wattage rating is on your speakings? meaning does it operate from 50-120 watts? It should be on a sticker on the back of them unless you have Bose, which nobody knows because they dont publish specs |
Silver Member Username: Frank_abela
Berkshire
UK
Post Number: 915 Registered: Sep-04
| Posted on Thursday, September 29, 2005 - 08:49 am: |
If you raise the volume enough that the amplifier starts distorting, it could damage your speakers if you kept on playing at that level. If you actually listen to the signal and realise that it's begun distorting, then provided you lower the volume enough to stop distorting, then there should be no problem. Regards, Frank. |
Post Number: 4 Registered: Sep-05
| Posted on Thursday, September 29, 2005 - 03:15 pm: |
the speakers just say 120max on the back Thanks for help guys |
