Thread: Comparing the HK AVR 335 vs AVR 430 |
New member Username: Brians
Michigan
Post Number: 4 Registered: May-04
| Posted on Wednesday, September 28, 2005 - 12:46 am: |
I'm looking to upgrade and have been shopping around alot. I came across these two receivers at harmanaudio.com. They're both factory refurbs with a 2 year warranty. They are both selling for $397 and wondering if any out there have any experience with either or how they compare. Both seem to have similar specs so looking for a reason to purchase one over the other. The 335 is the newer model, but the 430 has 10 watts per channel more. Anyone take a swing at these?? |
Gold Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 2258 Registered: Mar-05
| Posted on Wednesday, September 28, 2005 - 12:57 am: |
10wpc is a meaningless difference. Look closer for more significant differences in features, weight, etc. I would also look at the HK website, maybe call them directly and ask. |
Silver Member Username: Kano
Post Number: 687 Registered: Oct-04
| Posted on Wednesday, September 28, 2005 - 01:00 am: |
The 400 series is a step up in terms of DACs and processing. The 335 is a year newer model than the 430 and has a better auto set-up feature and more EQ options. |
