Thread: Car stereo receiv. in garage? |
New member Username: Trun
Post Number: 1 Registered: Sep-05
| Posted on Saturday, September 24, 2005 - 12:52 pm: |
Due to space considerations, I would like to try and mount a car stereo in my new garage/shop 24x30 size. 6 ceiling speakers would be nice. any ideas on how to do this? |
Wiley is....... Unregistered guest |
| Posted on Sunday, September 25, 2005 - 01:10 am: |
Buy the car stereo, buy the speakers and some cable then hook it all up. Let me know if you have any more questions. |
Post Number: 2 Registered: Sep-05
| Posted on Sunday, September 25, 2005 - 08:19 am: |
Wiley: your specific instructions are overwhelming. |
Wiley is.... Unregistered guest |
| Posted on Sunday, September 25, 2005 - 11:01 pm: |
Lucky you, I usually charge for my services but this one was so easy that I decided to put it on my tab. |
Bronze Member Username: Ncavman
N.C.
Post Number: 79 Registered: Dec-03
| Posted on Monday, September 26, 2005 - 04:43 pm: |
Simply wire it up. Stereo receiver to speakers (or rec'r line out->to amp->to-speakers if using an external amp). Use an impedance matching speaker selector for the speakers to keep the load on the receiver (or amp) what it should be. Use a 120v AC to 12V DC converter to power the stereo. A 24'x30' shop, and you are needing to save 8" on the stereo.... |
N.C.
Post Number: 80 Registered: Dec-03
| Posted on Monday, September 26, 2005 - 04:44 pm: |
Simply wire it up. Stereo receiver to speakers (or rec'r line out->to amp->to-speakers if using an external amp). Use an impedance matching speaker selector for the speakers to keep the load on the receiver (or amp) what it should be. Use a 120v AC to 12V DC converter to power the stereo. A 24'x30' shop, and you are needing to save 8" on the stereo....? |
