Thread: HT Starter System |
AdamVerducci Unregistered guest |
| Posted on Saturday, April 10, 2004 - 08:35 pm: |
Hi, I am just starting out and wanted to get a starter. Something that is upgradeable, but sounds good NOW and is still affordable. I'd like to get it all for around the very modest budget of $1200-1500. Here are some of the components I have been looking at. I will have a small/medium sized listening space with standard ceiling height. I listen to rock music most of the time and watch a lot of movies. Thus, I am not really interested in how a component sounds with jazz or classical. Like anyone else, I need my system to excel at the things I listen to. Receiver - I've heard excellent things about Denon, Onkyo, NAD and Marantz, and I believe I will stick to one of these four brands. Are there any other brands worth considering? Not a big fan of Yamaha and other brands' brightness. I like a good neutral sound, but also need to be able to crank it up. Not deafeningly loud, just loud enough to thoroughly enjoy my movies. Speakers - I have read strong reviews about the Athena AS-F2's. Went to Best Buy to give them a listen despite the warnings on this and other forums about that. What a waste of time. I think they had the speakers miswired as the bass response was awful, worse than the Athena AS-B1 bookshelf. If you know anything about the AS-F2, you'll know that it draws rave reviews for its bass response. Needless to say, whether it was the fault of the wiring or the Yamaha that was driving it, I did not have an opportunity to hear these speakers properly. I have considered Magnepans, but don't know if they will fit in with my music tastes. How do they handle rock at loud volumes? I have also considered old budget favorites Epos, PSB and Paradigm. Any others worth exploring? DVD - I have little success in researching a good budget DVD player. Any good sources for research? Recommendations? Sub - Considering Velodyne, Hsu and SVS. Would it be better to get one of these subs or one that matches with the pair of front speakers I get? Will a sub be even necessary if I get a pair of fronts with excellent bass response like the AS-F2's? Thank you for your help.
