Thread: Speaker to go with vsx49 txi |
Railwayman Unregistered guest |
| Posted on Saturday, April 10, 2004 - 10:31 am: |
I'm looking to upgrade my speakers, what would match best with my vsx49txi, I currently run Polk rt1000p, cs245, fxi300 and nht sb3 for surround back. TX |
New member Username: Levike
Cathedral City,
California
Post Number: 3 Registered: Apr-04
| Posted on Monday, April 12, 2004 - 11:58 am: |
Hey Since you've got the Pioneer Elite 49TXi I would recommend Definitve Technology speakers. The 49 TXi is an excellent receiver, I own the 43TX and I am very pleased.
Silver Member Username: Elitefan1
Post Number: 337 Registered: Dec-03
| Posted on Monday, April 12, 2004 - 02:58 pm: |
What is your budget and room size? |
| Posted on Tuesday, April 13, 2004 - 08:15 am: |
My room is 12'x26' and I'm looking to spend 3k for fronts and a center |
Post Number: 342 Registered: Dec-03
| Posted on Tuesday, April 13, 2004 - 04:44 pm: |
First of all I like your current Polks and would think they would sound very good with the 49txi. In my area the best speakers to pair with any Elite receiver are Monitor Audio and Dynaudio. Both are exceptionally clean and dynamic and sonically match perfectly with Elite. The Def Techs are certainly worth a serious audition since they make so many excellent models that will fit your budget and space. Even though I personally do not like the current Klipsch line I think you might want to hear them also. I would not pair a Elite with either Paradigm or PSB as both are to laid back. B&W might also be worth a serious listen. My local Elite dealers often pairs Elite and B&W, a bit to laid back for me but not to the level of Paradigm and PSB. These are just the brands in my area so maybe there is something else in your area to check out also. After all we are all sort of stuck with what is available in our areas. I would love to hear the current Snells but no dealers anywhere close. Good luck. |
Post Number: 343 Registered: Dec-03
| Posted on Tuesday, April 13, 2004 - 04:49 pm: |
First of all I like your current Polks and would think they would sound very good with the 49txi. In my area the best speakers to pair with any Elite receiver are Monitor Audio and Dynaudio. Both are exceptionally clean and dynamic and sonically match perfectly with Elite. The Def Techs are certainly worth a serious audition since they make so many excellent models that will fir your budget and space. Even though I personally do not like the current Klipsch line I think you might want to hear them also. I would not pair a Elite with either Paradigm or PSB as both are to laid back. B&W might also be worth a serious listen. My local Elite dealers often pairs Elite and B&W, a bit to laid back for me but not to the level of Paradigm and PSB. These are just the brands in my area so maybe there is something else in your area to check out also. After all we are all sort of stuck with what is available in our areas. I would love to hear the current Snells but no dealers anywhere close. Good luck. |
New member Username: Sully
Post Number: 1 Registered: Apr-04
| Posted on Thursday, April 15, 2004 - 10:45 pm: |
I ran a similar Polk system (RT1000p, CS400i, RT25i) with an Elite VSX-47TX for quite a while until the upgrade bug bit. After quite a bit of testing I ended up buying Vienna Acoustics mains, center and surrounds and they're fantastic. In fact, I've canned the separates notion for now. It'd cost a small fortune to improve the sound. IMHO, it's very important to listen to speakers through the same equipment you'll be using and if possible in your room. |
