Thread: Red/Black Speaker Wire to RCA - HELP ME!! |
Unregistered guest |
| Posted on Sunday, September 18, 2005 - 01:40 am: |
I have a pair of Sony speakers with the traditional speaker wire (red and black stripped wire) connections. I wish to connect these to my DVD player, which has RCA connections etc. I am not sure what to do and was wondering if anyone could help me? (If there is an adapter I can buy, or some way of stripping an RCA cable or SOMETHING!!) I would really appreciate someone's help, as there does not seem to be much info on this at all! |
| Posted on Sunday, September 18, 2005 - 01:42 am: |
I also have the same problem and would appreciate some help with connecting traditional speaker (red/black) wire to RCA cable connection. |
Silver Member Username: Kano
Post Number: 675 Registered: Oct-04
| Posted on Sunday, September 18, 2005 - 04:34 am: |
An RCA connection transmits audio, while a speaker wire transmits power. A DVD player does not produce power, it sends a signal to an AMP which produces power. You need a receiver. The Panasonic all digital goes for $250 and will compliment your Sony speakers well. |
Sammy101USA Unregistered guest |
| Posted on Sunday, September 18, 2005 - 06:13 am: |
Thankyou very much . . I will start saving for a receiver! |
New member Username: Rechmbrs
Conroe,
TX
United States
Post Number: 1 Registered: Oct-05
| Posted on Wednesday, October 05, 2005 - 03:56 pm: |
I have a related question. Receiver has clip type plugs for 2 wire and have 2 wire cable. Speakers have rca plugs. Can it be done? There are no rca speaker points on the receiver. Thanks, RON C |
Gold Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 2447 Registered: Mar-05
| Posted on Wednesday, October 05, 2005 - 04:00 pm: |
RadioShack is your friend. They'll hook you up for a few bucks. |
Conroe,
TX
United States
Post Number: 2 Registered: Oct-05
| Posted on Wednesday, October 05, 2005 - 04:50 pm: |
Thanks. I went to Radio Shack and picked up rca plugs but when reading the instructions on the back it says that both a positive nd ground must be connected. The speaker wire is two wires. Does this mean that both wires from the receiver go to one rca plug? Sorry for being so dense. The hardware etc. is many miles from so I'm helping (???) them by phone. Thanks, RON C |
Bronze Member Username: Chrise
Post Number: 13 Registered: Jan-05
| Posted on Wednesday, October 05, 2005 - 08:04 pm: |
Eddie, For the good of the forum, why don't you jump in the car and drive to Conroe and help? This thread is hurting my head. Chris |
Conroe,
TX
United States
Post Number: 3 Registered: Oct-05
| Posted on Wednesday, October 05, 2005 - 08:34 pm: |
Chris, If you think this thread hurting your head, don't look into it. Some of us are not as knowledgeable as you. Too bad about your attitude. RON C |
Post Number: 14 Registered: Jan-05
| Posted on Wednesday, October 05, 2005 - 08:42 pm: |
Ronald, No offense meant....in retrospect I shouldn't have posted it. Take care. |
Post Number: 15 Registered: Jan-05
| Posted on Wednesday, October 05, 2005 - 08:46 pm: |
Ronald, OK......your speakers have RCA plugs? Are you sure??? What type of speakers are they? Chris |
