Thread: Cambridge azur 540A Biwire?? |
New member Username: Pats
Post Number: 1 Registered: Sep-05
| Posted on Wednesday, September 14, 2005 - 04:09 pm: |
I've recently bought a cambridge azur 504A amp and 540C CD player along with some MS 902 bookshelfs my current set up is to have it bi-wired (recommended by the retailer) The amp has the ability to run to sets of speakers and i was told to wire up the bass for left and right to speaker set A and the treble for left and right to speaker set B My head tells me this is wrong. It sounds fine but just seems strange that i should do it this way. with true bi wire amps do the hi and low feeds from the amp carry different signals or is this handled at the speaker end by the crossovers/hi and low pass filters also will the set up i have put any undue strain on my amp help much appreciated pat |
Silver Member Username: Sun_king
Leeds,
West Yorkshire
UK
Post Number: 289 Registered: Mar-04
| Posted on Wednesday, September 14, 2005 - 05:21 pm: |
No, you're doing it correctly. Whether it is actually any better than using a single run of wire is for you to decide! True or 'proper' biwiring involves rewiring your speakers, ie taking out the crossovers and either running external ones or putting in new ones. In my own experiments into 'basic' biwiring, the way you are doing it, I found that only certain speakers responded well. In a lot of cases a good quality run of single wire was actually better than a double run of biwire worth the same price - ie it's often better to spend more on a single run of good quality speaker cable than to spend the same amount on two runs of bi-wire. Makes sense to me. |
Leeds,
West Yorkshire
UK
Post Number: 290 Registered: Mar-04
| Posted on Wednesday, September 14, 2005 - 05:23 pm: |
Oh and no, it puts no more strain on your amplifier as the speakers are still drawing exactly the same amount of current. |
Silver Member Username: Stu_pitt
NYC,
NY
Post Number: 526 Registered: May-05
| Posted on Wednesday, September 14, 2005 - 06:16 pm: |
Someone else posted a similar question about Cambridge Azure integrateds and said that Cambridge actually recommended to not bi-wire. Something about A and B were only designed to be used together for a short period of time, and not permanently. It sounded weird to me, but I remember seeing it in one of these posts. Personally, I'd see what the manual says, and if that doesn't clarify it, I'd e-mail Cambridge. |
Post Number: 2 Registered: Sep-05
| Posted on Thursday, September 15, 2005 - 04:18 am: |
thank you both for your quick yet contradicting replies i'll contact cambridge then. does anyone know how to contact them. i went on their site but couldn't find any contact details. there is a forum on there tho so i might post on that as well thanks again pat |
NYC,
NY
Post Number: 534 Registered: May-05
| Posted on Thursday, September 15, 2005 - 12:47 pm: |
Patrick - 99% of the time bi-amping isn't a problem. I can't find where I read that it wasn't advised for these amps. It may have been another Cambridge Azure amp, but I felt compelled to give you a heads up. |
Post Number: 3 Registered: Sep-05
| Posted on Friday, September 16, 2005 - 04:42 am: |
hey all i've been on the cambride audio forum and found a similar posting that was already there and everyone seemed happy about the idea so i can only assume that its a safe thing to do. happy listening |
New member Username: Timothy
Post Number: 1 Registered: Jan-06
| Posted on Friday, January 20, 2006 - 01:26 am: |
Bought the CA Azur 640a and 640c both in v2. Bi-wire the 640a with my years old PSB Century 900i floor standing speaks without any problem. Yesterday I changed the PSB to Kef Q1 and did the same bi-amp but 640a CAP5 protection light went on flashing 6 times during start up and the 640a just didn't get back to ready mode. Once experiement i did was to just connect Kef Q1 to the 640a on speaker a which runs fine. When i just ON the speaker B button then 640a protection light went 6 times again and stop. Anyone knows what is going on? |
