Home > Message Board > Home Audio > Receivers > Archive through October 05, 2005 > Receiver Question for NYC Apt...
Author Thread: Receiver Question for NYC Apt...
Username: Stone2662
Brooklyn, NY
Thanks in advance for all your tips. I have a new Pioneer Elite HD Plasma, and I'm searching for a good av receiver - usage will probably be 70/30 music to video. We're in an decent sized apt in NYC, so we don't need massive power, but I don't want to skimp too much. In fact, I'm pretty much set on the Monitor Radius surround speakers (the 90's, 108 center and 360 subwoof).
I've gotten a wide variety of glib recommendations from the high-end audio stores: Marantz 7500; Arcam 250, Integra 5.5. I was told by one that I didn't need to spend the $$ on the Marantz 7500 as it would be "too much" for the speakers and space. Do the Monitor speakers require less power due to their size? Our budget is around $1000 plus or minus. Interestingly enough, I haven't heard any recs from these salesmen about HK, Denon, Pioneer, etc. ALso - what abotu the new Outlaw 1070 receiver - which I believe is only 65 amps/channel?
I really want a system that is primo for music..any suggestions? Thanks!
Username: Devils_advocate
Post Number: 370
My suggestion would be to check out the new all digital amplifier from Panasonic. Our own Edster922 has written a pretty good review of it here, and compares it with his Marantz 5400 and his NAD seperates equipment. In the end it seems as though he will be selling his Marantz...which you could also pick up for cheap probably!
Anoni
How ironic,
The man mentions Marantz, Arcam, Integra etc and now turns out that a cheapie Panny is the first recommendation.
What the world has come down to !
I would really like to compare the Panny against my two monoblocks....mmmm $15.00 for freight...maybe. Still, no way the little guy can beat the power I am getting now...just no way.
Maybe for decent bookshelf speakers the Panny is ok but for big power hungry floorstanders ...I just can't see how....
oh, back to the original question,
I'll say another option would be the Pioneer Elite VSX 54....
Username: Paul_ohstbucks
Post Number: 2388
With a budget of $1000, I would recommend receivers in this order.
1.Yammi2500
2.Denon3803
3.PioneerElite54
Home > Message Board > Home Audio > Receivers > Archive through October 05, 2005 > Receiver Question for NYC Apt... [ « Previous ] [ Next » ]
