Thread: Best bang for the buck |
Unregistered guest |
| Posted on Tuesday, April 06, 2004 - 03:21 pm: |
i have a mitsubishi 65in. tv a dennon 1804 a dennon dvd910 and right now a sony surrond system im looking for new speakers for a 5.1 setup.. I was looking at either definitive pm900 for front and pm500 for rears or nht or b&w what would yoou guys suggest i get ny room size is about 20x20 with vaulted cielings and onopens to the kitchen so i really only have three walls to work with |
| Posted on Thursday, April 08, 2004 - 11:20 am: |
please help
Silver Member Username: Project6
Post Number: 434 Registered: Dec-03
| Posted on Thursday, April 08, 2004 - 02:20 pm: |
the definitves are very nice and should really bring out the detail in your movies and music. However, I would also look at replacing your Sony surround sytem, they are really holding back the Definitive's properties, I'm not sure what type of Sony system you have, but they usually have weak power supplies. For the Definitive's I would get an HK or a NAD. cheers |
Silver Member Username: Elitefan1
Post Number: 326 Registered: Dec-03
| Posted on Thursday, April 08, 2004 - 03:47 pm: |
johnk, I take it from your original post you have a Denon 1804 receiver and are looking for a good surround system to match with it. You have not stated a budget but my recommendation without breaking the bank would be Paradigm Monitor 7 for fronts, the cc370 center and the Mini-Monitors for surrounds or if you want dipolar surrounds the ADP170 or any other of their dipolars. The PS1200 would be the sub I would go with. It would be hard to find a better system for the money to match a Denon with and would fill your space very nicely. I would not pair the Denon with the Def Tech's; to bright for me. Good luck and check out Paradigm's website for specific info. |
| Posted on Thursday, April 08, 2004 - 09:41 pm: |
therealelitefan---would this be a good system for sacd and/or dvd-audio? |
Silver Member Username: Hawk
Highlands Ranch,
CO
Post Number: 468 Registered: Dec-03
| Posted on Friday, April 09, 2004 - 01:25 am: |
johnk: Well, we all have our own bias, depending upon what we like, but I would suggest NHT speakers for your set up. In particular, I would strongly suggest the new L-5, which is an on-wall mounted three way speaker that is simply superb. You have not suggested a budget, but the L-5s can be had for about $350-375/each (check with Kiefs for current price--www.kiefs.com for the phone number). NHT is a very good match for your Denon, too. |
