Thread: Sharp XL- DV50 Protect message |
New member Username: Likwidsoul
Post Number: 1 Registered: Sep-05
| Posted on Friday, September 09, 2005 - 06:28 pm: |
Hi, I have Sharp XL- DV50 shelf mini-system. When I power it on, I get message on LCD pannel "Protect", and can't do anything about it or operarate the system. Does anybody know how can I solve this problem? |
uglyboywith11fingers Unregistered guest |
| Posted on Wednesday, October 05, 2005 - 03:39 pm: |
I have same thing with a SHARP CD-C2900... "Protect" message when power applied. anybody have any thoughts ? |
zizzergirl Unregistered guest |
| Posted on Wednesday, October 12, 2005 - 07:48 pm: |
I have the same problem, searching for a clue on this. Nothing in the manual's troubleshooting guide can work with it in this condition, but I tried anyway to no avail. |
BAP_In_WA Unregistered guest |
| Posted on Monday, October 17, 2005 - 06:38 am: |
I googled "SHARP CD-C2900" and found this page. I started having problems with the CD player on my CD-2900 a couple years after I got it. Now I don't even use the CD player. I use it as a sound system for my computer and it works really well for that. It was strange though. First I started getting an "Error" message, then after a while, the CD player quit working completely. Oh well. It sure sounds good! I have had it for over 6 years now. Everything else still works! ; - ) |
TraceyF Unregistered guest |
| Posted on Sunday, February 05, 2006 - 06:20 am: |
Hi guys..Just a quicknote, I too am having the same prob re: PROTECT MODE..i have had the system into a repairer as it was a curcuit blown and it cost me $120 to fix.That was 2 weeks ago and just today it has done it again,only this time I am able to turn it on THEN it goes into protect mode.There is a site,possibly the sharp site that does a step by step into fixing the prob.It says that if you cant fix the prob THEN take it into a repairer.I just cannot seem to find the site !!!! the step by step involves pressing buttons on ure system as soon as it powers up,I just cant remember the sequence,or,even the buttons haha...anyway...if anyone finds the solution..post it !! Cheers Trace |
New member Username: Teecee
Post Number: 1 Registered: Jul-06
| Posted on Friday, July 28, 2006 - 08:40 am: |
XL-DV50H PROTECTION FAULT Diagnosis of a faulty fan motor was made in my system. the fan motor sends signals to a microprocessor and prevents over heating of the system. the faulty fan was responsible for the protection message |
New member Username: Cody_read
Winnipeg ,
Manitoba
| Posted on Monday, July 31, 2006 - 01:58 am: |
I have a SHARP CD-C2900 and i plugged it in and im getting the message on the desplay that reads ERR 0101 and the stereo works for everything other then the cd player can anybody help me out |
New member Username: Nitram_laup
Wellington New Zealand
Post Number: 1 Registered: Nov-06
| Posted on Friday, November 24, 2006 - 05:06 pm: |
XL-DV50H PROTECTION FAULT I have this same problem. I took it to a repairer who charged $190 to repair the Fan Motor. 3 Months later I have the same fault and am not convinced that it is a "Fan Motor" problem. I can get it working by reducing the volume to around 12-14 on the dial, but if I want to really hear the sounds, then it just goes into PROTECT mode. Also the Sub Woofer has just stopped alltogether. Has anyone had a real and permanent fix to this problem? |
New member Username: Jim7221
STURMINSTER NEWTON United Kingdom
Post Number: 1 Registered: Nov-08
| Posted on Monday, November 03, 2008 - 06:15 pm: |
Hmmmm.... 2 years on and I wonder if ppl sorted out the problem... or just got new eqpt!!!...lol Anyway, I have a XLDV50H and read up on this forum about the "protect" message discussion..... note the refs about 'faulty fan'.... from my investigation it looks as though the fan control circuit is at fault; therefore the unit is overheating....solution??... well, i have bypassed this so the fan will run constantly when the unit is turned on........... so far... so good!!..... so if you dont mind doing a bit of soldering and can trace a cct board its pretty easy.... IF my unit ever does go into fault again Ill let you know..... JK |
