Thread: AUX |
New member Username: Astrosafari
Delhi,
Ontario
Post Number: 8 Registered: Aug-05
| Posted on Friday, September 02, 2005 - 07:43 pm: |
on my stereo there is an 'AUX' setting. what is this? what does it do?? |
Gold Member Username: John_a
London U.K.
Post Number: 3747 Registered: Dec-03
| Posted on Saturday, September 03, 2005 - 04:51 pm: |
"Aux" is short for "Auxiliary", and identifies an input. |
Delhi,
Ontario
Post Number: 9 Registered: Aug-05
| Posted on Sunday, September 04, 2005 - 08:53 pm: |
what do i input to it?? can i hook my computer up to it?? so i can use the stereo to play the audio from music and video instead of the sh*t speakers i have |
London U.K.
Post Number: 3753 Registered: Dec-03
| Posted on Sunday, September 11, 2005 - 12:01 pm: |
Yes, anything. You need to connect the source, which can be a computer, to the stereo. Connect the audio output of the source to the stereo's aux input, using whatever fits. A mini-jack or a pair of RCA plugs can be at either end of the connector. There should be an aux input on the stereo. Switch to "AUX" to select it. |
Silver Member Username: Stu_pitt
NYC,
NY
Post Number: 494 Registered: May-05
| Posted on Sunday, September 11, 2005 - 06:17 pm: |
To add to John's post - the only thing that won't work in the AUX is a turn table. If the turn table has a pre-amp built into it - very few do - then it will work. |
