Home > Message Board > Home Audio > Receivers > Archive through October 05, 2005 > Harmon Kardon AVR 85 Red LED problem....
Author Thread: Harmon Kardon AVR 85 Red LED problem..HELP!
Username: Steverse
I recently had a fuse blow out on my reciever. i replaced it and then put the cover back on. when I turned the power on, the LED was red instead of green. manual says it needs to be reset. Does anyone know how to do that?
Username: Thx_3417
Post Number: 1293
Steve,
There could well be a small button inside the Harman Kardon AVR 85 although don’t quote me on that, get some good light on it and take a look on the inside making sure power supply is turned of and disconnected as well.
If there is in fact a small button, there may well be a backup battery powering the memory for the unit.
Check it out be careful too.
Ashley
Username: Kano
Post Number: 629
Hold the MEMO and CLEAR buttons on the front panel for 3 seconds to reset the unit.
Username: Steverse
I tried pressing memo and clear and the unit did reset but red light is still on. Does that mean there is another blown fuse somewhere?
Username: Steverse
can anyone help on this?
Username: Jan_b_vigne
Dallas, TX
Post Number: 5737
Probably HK can help.
Username: Stu_pitt
NYC, NY
Post Number: 541
Or a service center
Home > Message Board > Home Audio > Receivers > Archive through October 05, 2005 > Harmon Kardon AVR 85 Red LED problem.... [ « Previous ] [ Next » ]
